Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
1200post
Posted on: 2007/9/20 7:32
Anything is possible as long as you put your mind to it hope to hear how you go
#12
Team_Dat
Posted on: 2007/9/20 8:09
The 1200 post is shorter than a 1200 sedan this you must consider when building your toy why do you call it a 1200 post? PS build it!
#13
stirlingmac
Posted on: 2007/9/20 8:24
The trick is to use the longer wagon/van doors as these match the windscreen pillar angle and are the same height in the door opening. Then slice the B pillar and shift it back to suit.
#14
phunkdoktaspok
Posted on: 2007/9/20 8:36
1200 glass is not flat. And you will be paying good money for an Australian Automotive ADR approved glasier to make the glass. ( I researched long and hard when i chopped my old 1200 wags.) 4 door sedan rear door glass swapped to opposite sides will give extra length but may or may not wind all the way up because of the curve needed at the top front. Moving the Bpillar on 1200's is as easy as drilling out the spot welds and sliding it into the desired position.
#15
1200post
Posted on: 2007/9/20 9:34
just all ways known them to be 1200 post mine came from south africa in 69 ive owned it for 16 years now
#16
Posted on: 2007/9/20 21:11
1200 post mine came from south africa in 69 Jan 1970
#17
1200post
Posted on: 2007/9/21 2:22
b110 1200 one of the first
