A15 5sp 1200 build - Suggestions
From South Africa
I have a 1975 1200 B110 4 door (South African version) with a poked A12,
I have just picked up a clean A15 with points style distributor as well as a FS5W60A out of a 1994 Nissan 1400 pick up (still in production here) due to a bit of highway driving I do.
I plan the following:
Twin 40mm DCOE
Posted on: 2007/9/20 10:02
Re: A15 5sp 1200 build - Suggestions
From gold coast
i gota a15 worked with a celica 2t gearbox....very fast ute...i would recomend 2-1/4 mandrel bend exhaust & 30/70 cam...i got the diff ratios changed and custom tailsharft....they say i am boarder lining it with a standard diff behind my motor so put the diff on the to-do list deffently
Posted on: 2007/9/21 22:09
From sydney
I think you should both be fine with the ute diffs, if you are sticking to the A15s.
Posted on: 2007/9/21 23:06
