micra engine
From Sydney
hey guys and girls was just wondering about the micra engine and if anyone know if it would possibably fit into a 1000 as i have located one with the multi coil ignition and would love do this as no has done it before and would be a 1 of a kind car if any one has any info on this it would be much appreciated. and would like it legal
Posted on: 2007/9/23 6:11
Re: micra engine
From south australia
aney thing is possible if you throw enough cash at it and yes it would be verry unique
i gues the hardest part would be working out what gear box to use and having a bel housing adaptor made for it
Posted on: 2007/9/23 6:41
Re: micra engine
From Brisvegas, oz
you would have to think why?? its going to cost a bucket load and really what are you going to get out of it (a gutless engine) you may aswell go somthing more powerful
Posted on: 2007/9/23 7:28
www.camerasplus.com.au
Re: micra engine
From Sydney Australia
hey mate,
there was a thread on this a couple months ago. it was pretty much decided that it would be a great engine. there is alot of parts avaliable from japan for them. The only problems was the ignition and gearbox, so if this one has the multi point there is only one real problem. I say go for it. I think it is lighter than the a series as well.
cheers
Posted on: 2007/9/23 8:19
Re: micra engine
From Sydney
it may be a bucket load but who in the world would have one :) also there not that gutless and its modern more reliable then an a series and yeah gear box is where i am abit worried but a custom bell housing might do it
Posted on: 2007/9/23 10:36
Re: micra engine
From Brisbane
Relevant Micra info and goodies..
http://www.datrats.com.au/MICRA%20K11.htm
Posted on: 2007/9/23 10:49
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: micra engine
From Mandurah, Western Australia
Micra engine is a great engine. They are extremely restricted in the micra with 2 catalitic restrictive exhaust, restricted inlet etc. Good gains are to be made in this area. Just do a search on the available aftermarket options for these cars in the UK.
The engine is very reliable and revs hard. To look at it is a scaled down sr20.
The problem is the dizzy is at the end of the motor and may hit the firewall in a 1200.
But my daily driver micra still going with 200 000 on the clock, 1000 k a week and driven hard.
Posted on: 2007/9/23 12:06
Re: micra engine
i belive errol was looking at the micra heads agaes ago but the enigine is very doable as compact providing you can adapt gearbox and dizzy.
They do go hard and are more looked upon as a scaed down version of the old suzuki gb13 gti motors.
Groupe e cams and cam timing with ecu and free flow inlet and exhaust will have no trouble with other cars.
Remember may have less total hp than some other conversions but chances are it may be quicker than some as you could get the power to the ground more easily.
Posted on: 2007/9/24 0:51
Re: micra engine
Hey unfamilia thank goodness its not the case. They are are not a scaled down version of suzuki at all but as mentioned the SR20 but with the ga16 head design :) even better than the suks!. They are available in the same sizes as the suzuki G series twin cam and actually even bigger.
The micra is available in a twin cam 1.4 litre in the last years where suzuki g series dont have a true G series based twin cam above 1.3 unless you use the sohc g16 block and swap the heads to make a hybrid which is going backwards as the sohc 16v g series is better in valve sizes and port shapes.
Also the only solid crank version (no hollow mains) remains the 1.3 versions.
The micra is a bullet proof engine that as mentioned with xhausts mods will match and even outdo many similar 1.6 engines. With boost now some are almost hitting 300hp and increasing. NA race version hitting over 10k rpm all day and speedway adopting them soon they are special.
The main thing to remember is that datsuns are light and the running gear to be replaced should be the same. At around 80kg dressed and under that in race trim how can you go wrong?.
Posted on: 2007/9/24 2:12
Re: micra engine
you know whast i think would be the best idea in the world?
If some one would develope a kit for the open market to fit thease motors to the 1000 b10 its a match made in heven hey scott
Posted on: 2007/9/24 11:58
