« 1 (2)
Re: Rotary or toyota engine conversion?
From Bris-Vegas
I suppose it depends whether you want it to be legal or not.
13BT = Illegal in most states, but truly awesome to behold.
4AGE = Legal, but with heaps of stuffing around to fit into a 1200.
CA18DET = Legal, heaps of info & conversion parts available.
And - HEAPS OF FUN.
Go the CA18 mate
Posted on: 2007/9/26 10:21
CA18DET '74 1200 ute project
From Darwin NT
yeh and heavy for what it is
Posted on: 2007/9/26 11:40
current project 4x4 patrol...
From South Africa, Bloemfontein
Remember what I wrote previously.
We are unlimited here in ZA.
Easy power and light weight = 13BT.
Insane power.
Why don't you keep it original with some throttlebodies? Don't forget, power is nothing without handling and good brakes.
Posted on: 2007/9/26 11:52
1977 Datsun 1200GX
From Auckland N.Z
Im a bit biased because I'm running the toyota 4agze, but I did a lot of research and I think it is the best as far as weight/power/economy and access to parts are concerned. Ok it's not as powerful as a rota but it is much better on fuel (and how much power do you need) and it is a lot lighter than the CA or SR and I've found parts (in NZ) very easy to get. with the motor being rebuilt and running a T3/T4 turbo I should be looking at 210 - 230kws which is heaps and it will still drive in traffic.
Posted on: 2007/9/26 12:37
I totally forgot about fuel economy.
The 13BT is definately going to be a killer with fuel economy.
4AGE will be a better option then.Not as much power as the rotary but definately better fuel economy and still good power for it's size.
Posted on: 2007/9/26 13:31
1977 Datsun 1200GX
From Cape Town ZA
I don't know about that, I bought a 4AGZE, a conversion bell housing for a W58 celica box, bolted them together and spent the next hour to slide the engine gearbox combo in and out about 3-4 times, and beating out a little space around the box in the tunnel. I eventually found out this wasn't really needed. The biggest job was to manufacture the engine mounts, which took me about an hour after the original towers were cut off. So no stuffing around really.
I might be a bit biased as well, but where reliability and availability of parts are concerned, I seriously think you are better of doing the 4AGE/ZE than a rotor. On this ground the CA/SR engines are just as good, I haven't really seen the one being more/less reliable than the other, and both make big numbers in the power area.
Here in SA at least there are more performance parts available for the 4AGE and it's variants than say the CA/SR engines or the rotors. And because of their popularity there is also a wealth of knowledge around.
I get goose bumps just thinking about a proper rotor setup, but I'm a bit weary of people's knowledge of them in ZA, and their parts are extremely difficult to come by and expensive to boot. However, it's always good to be different too...
Have a look at the pics in my profile, and you can see the whole build... I did the 4AGZE with turbo...
Posted on: 2007/9/26 15:12
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
I talked the other day to a guy that installed a rotary in his bakkie.
Naturally aspirated 13B with a 52 Weber carb.
The apex seals cost him R9000 (ZA Rand) for good quality ones.
With that kind of money you can rebuilt a 4agze I would think, TWICE.
Posted on: 2007/9/27 6:44
1977 Datsun 1200GX
From Cape Town ZA
Geesh for R9000, if you go to the importers and bargain with them, you can buy two 4AGZE's or 3 NA 4AGE's.
I bought my engine, opened the tappet covers to check for excessive rust, found nothing other than a little surface rust. I then removed the sump to fit the turbo return, and wiped out the surface rust as much as I could. That's the extent of the work I did on the engine. The engine runs like a dream, and doesn't use any oil at all. Point is, you don't have to open it up or rebuild it, just look for a nice engine in good condition, with not to much oil on the outside.
If you buy a 4AGZE no need for forged pistons either, and the same goes for the turbo'ed CA/SR Nissan engines.
If you have a mega budget, and really want to be different, go for the rotary, otherwise go for the CA/SR DET or 4AGZE engines...
Posted on: 2007/9/27 7:24
1200 GX Sedan
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
I think very few people in ZA have a mega budget.
Posted on: 2007/9/27 7:58
1977 Datsun 1200GX
From Sunnybank, Brisbane
i got a ca ute (common as bums) but a mate of mine had a 4agze ute with upgraded supercharger more boost and a few other mods, my ca has WAY more top end and its basically stock.
id be heading the rotor option myself, they make CRAZY power so long as you can get it on the ground (without regulations im sure you could tub it)
id personally not want a rotor but i have alot of respect for em and if your chasin power from small cubes you cant beat em
Posted on: 2007/10/13 5:11
« 1 (2)
