can someone tell me???
From Adelaide. SA
I have just put stock 1200 disc brakes on the front of my 1200 sedan, my question is are drum brake rims and disc brake 12" rims the same?? When I apply the brakes I get a small knocking sound from the front (caliper hitting on rim) Are the rims the same or do I have to find some other rims??
Cheers. Adam.
Posted on: 2007/9/27 22:56
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
Re: can someone tell me???
B110 drum-brake wheels
B110 diske-brake wheels
...are the same.
Later B210 wheels are different, they have a little more room inside (in diameter, not offset).
Posted on: 2007/9/27 23:34
From Adelaide, Australia
Its not a wheel bearing loose is it Adam? Also could be strut insert a little loose or caliper even.
Posted on: 2007/9/28 7:08
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Adelaide. SA
Yeah im gonna check the calipers before the bay to birdwood.
Cheers
Posted on: 2007/9/28 7:43
Peter Brock
Could even be the split pin that holds the pads in.
Goodluck matey I'll be up early out on anzac hwy waving you boys on!!
Posted on: 2007/9/28 7:45
IPRA Build
