#1 BEST CARBS FOR STOCK A14
webbs1200 Posted on: 2007/10/2 22:51
I AM DROPPING A STOCK A14 IN MY 1200. I WOULD LIKE TO USE MY TOMEI MANIFOLD, WHAT SIZE CARBS SHOULD I USE ?
#2 Re: BEST CARBS FOR STOCK A14
sidedraught Posted on: 2007/10/2 23:22
Is the Tomei Manifold for twin sidedraught Webers? or something else?
If its for the twins I would go for 40mm but I would also get the cam reground to a sportier grind to take advantage of the carbs.
Also I would check on the clearances to brake master cylinder if the car is left hand drive before investing in carbs that are going to foul.
#3 Re: BEST CARBS FOR STOCK A14
webbs1200 Posted on: 2007/10/2 23:54
THE MANIFOLD IS FOR TWINS. THE CARBS I HAVE FOR MY MODIFIED A14 ARE TO BIG FOR THIS MOTOR.
#4 Re: BEST CARBS FOR STOCK A14
D Posted on: 2007/10/3 0:36
get your modified ones re-choked and rejetted you can keep the old parts in case you go back to the beast setup its very easy to change back.
