Re: 1600 front struts
From Auckland N.Z
Yea thats a good point, they will need to be spaced out anyway. Cheers man.
Posted on: 2007/10/3 22:04
From Geelong, Vic
all the later struts will give the same amount of extra track width
the r31 and such extra wheel clearance is only really handy when running bigger wheels(16s and 17s) as far as i know
if making your own bracket id go for the stanza, 200b 240k struts
but as white sedan said, brackets are available for some struts so might be better of pricing them up and seeing what struts they are available for
$600 for just the front brakes hey sean, i did the whole r32 setup front and rear and had change left over from $600
Posted on: 2007/10/4 3:35
From Adelaide, Australia
Yeah but for $600 you get two sets of race pads one hard/one soft, braided flex lines (got some already but every dato owner needs spares), dogbone brackets, pair of brand new 4spot superlites, new drilled rotors and billet rotor mount all bolts up to the 280zx strut leg.
This wont happen for at least a year or two, I got to get the car out and stretch its legs and wear out the brakes that are on there first.
Posted on: 2007/10/4 9:30
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Auckland N.Z
hey whitesedan what site/company did you get the brakes from, for $600 I'm keen to get some!
Posted on: 2007/10/4 12:22
I cant find Rods Fabrications on ebay US anymore??
These guys do the mounts and stuff
Ebay for caliper mounts and rotor mounts
Posted on: 2007/10/4 12:35
IPRA Build
Wow found it, I know why I couldnt also,
PAULS FAB & PERFORMANCE
Posted on: 2007/10/22 9:18
IPRA Build
Not too shy to talk
From perth wa
hey white sedan, set a post up for the 280zx struts and brake conversion once u r done as i have a set of 280zx struts sitting in the garage. sounds like it will be a much better set up than the 120y disk brakes at the moment...
Posted on: 2007/10/22 12:38
why is it that the wife does not think i am serious when i say she will go before the datto ??????????????
Its all in the Wiki mate.
Same conversion parts as sunny/stanza strut swap except remove the spring seat and run a standard sized spring seat or weld on coilover kit like I did.
Ends up looking like this;
Posted on: 2007/10/22 12:42
IPRA Build
Not too shy to talk
From perth wa
that is bloody awesome
i will definetely keep that one in the memory banks the first time i crap myself from brake fade. u just saved me from throwing them away.....
Posted on: 2007/10/22 12:47
No wuckas!
Posted on: 2007/10/22 12:50
IPRA Build
« 1 2 (3)
