Re: dump pipe vs cannon
Just get a 2.25" 45degree bend and weld it on. Any exhaust aimed towards the ground will give a much deeper sound, as it will echo off the ground.
Dump pipe - dumpy tip - soft cock. Im sure these internet gangstas still know what you are refering to.
Posted on: 2007/10/5 8:31
From whakatane, but most of the time canterbury NZ
The dumpy tip you refer to phunk will also aim the exhaust gases towards the ground so it will also give a deepepr sound....
Posted on: 2007/10/5 10:15
Experience is directly proportional to the amount of equipment ruined.
From South Africa, Bloemfontein
I am also about to change my exhaust pipe's tip to a 45 degree dump pipe.
Mine is 2inch exhaust, but I want to get a stainless steel one, mandrel bended and then polish it up to a shine.
Posted on: 2007/10/5 10:37
1977 Datsun 1200GX
From campbelltown (sydney) australia
my ute has got a 45 degree dumpy but they have tucked it up higher than the bottom edge of the tray so u can see it looks good without exhaust tip showing
Posted on: 2007/10/5 10:40
* caution, sunglasses must be worn to view my ca18det *
From Sydney
hmm if its a a-series dont matter wat exhaust u have they always sound the same...
Posted on: 2007/10/5 11:56
From gold coast
rito thanks boys...phunk so u rekon i get a 45degree made outer 2-1/4 and put that ova the 1-3/4....anyone got any idea why they would go 2-1/4 to the box then that little skiny s#%t at the end?
Posted on: 2007/10/5 23:17
Ah I misread the other post and was thinking the exhaust was all 2.25".
If its 1.75" at the back, Just get a 45 degree 1.75" bend. The size of the tip wont change the sound.
Im as the same thoughts of a few others, paint it black or hide it up high.
I wouldnt bother wasting money on mufflers just to get a desired sound.
Posted on: 2007/10/6 1:13
From Townsville, Qld
I reakon most exhausts ruin the shape of our cars that's why mine is dumped back before the diff. However that ute with the twin pipes would be mad with a hi po CA powering it and flames to boot during every gearchange or backing off of the accelorator.
Big pipes are for cars that have enough power to need them. That's got me thinking again though as I have a set of Arrow extractors I was going to throw on the car, I think the collector pipe diameter is 2 inch but it may be bigger
Posted on: 2007/10/6 1:54
From gold coast
my tip is 3inch tho...pretty much exzact same as the blue ute above...reakon i get the back pipe remade out of 2.5inch?
Posted on: 2007/10/6 2:40
« 1 (2)
