Re: help needed: e15 dissy fitted and cutting out under load
From melbourne VIC
i found the problem, it was the coil all along.
i pulled the coil out of the pulsar and wacked it in, thankfuly no more cutting out.
it still doesn't run 100% but a brand new coil, dissy cap and rotor button should fix that
to every1 that replied, cheers
Posted on: 2007/10/5 14:27
Subject Poster Date
     help needed: e15 dissy fitted and cutting out under load gino_120y 2007/10/2 14:49
       Re: help needed: e15 dissy fitted and cutting out under load LAGWAGON 2007/10/3 1:46
         Re: help needed: e15 dissy fitted and cutting out under load utheremate 2007/10/3 3:21
           Re: help needed: e15 dissy fitted and cutting out under load Anonymous 2007/10/3 10:13
             Re: help needed: e15 dissy fitted and cutting out under load gino_120y 2007/10/3 11:39
               Re: help needed: e15 dissy fitted and cutting out under load beattie 2007/10/3 11:55
                 Re: help needed: e15 dissy fitted and cutting out under load Anonymous 2007/10/4 8:45
                   Re: help needed: e15 dissy fitted and cutting out under load gino_120y 2007/10/4 13:10
                     Re: help needed: e15 dissy fitted and cutting out under load beattie 2007/10/4 13:13
                     Re: help needed: e15 dissy fitted and cutting out under load gino_120y 2007/10/4 13:29
                       Re: help needed: e15 dissy fitted and cutting out under load beattie 2007/10/4 14:34
                       Re: help needed: e15 dissy fitted and cutting out under load phunkdoktaspok 2007/10/4 14:41
                         Re: help needed: e15 dissy fitted and cutting out under load Anonymous 2007/10/5 4:20
                           Re: help needed: e15 dissy fitted and cutting out under load WhiteSedan 2007/10/5 8:13
                             Re: help needed: e15 dissy fitted and cutting out under load gino_120y 2007/10/5 14:27
