« 1 (2) 3 »
Re: perfect fit in the 1000 coupe
From Adelaide. SA
Just cut the tunnel out of the commodore. the first 30-40 cms should be enough. there is actually heaps of room in the 1000. the only real stumbling point will be the exhaust manifolds..... (so far)
Posted on: 2007/9/29 11:18
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
From Geelong, Vic
you probably dont have to cut as much as me for the tunnel, ute is a few cm off the ground and auto was tucked way up so not to hit stuff, so the whole auto is above floor level
as its a series 1 motor modding the exhaust manifolds shouldnt be a problem(should have mild steel manifolds), havnt got around to that on mine yet either...just cut them so they fit in
Posted on: 2007/9/29 11:24
From Adelaide. SA
The motor i'm going to use is a series 2. the manifolds appear to be shorter so they should clear everything nicely
Posted on: 2007/9/29 12:20
Peter Brock
From Coondle, WA Australia
This is possibly the most awsome conversion ever done for a 1k. The dunny dore v6 has so much potential to proform, and in a 1k with so little weight. Oh yeah baby.
Just dont try and turn too many corners
Posted on: 2007/9/29 14:43
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Adelaide. SA
Today I re fitted the motor with suspension and steering in place.
I have modified the sump to sit the motor about 40mm back towards the fire wall.
With the top control arms in place i will have to make some custom headers.
I have also cut out the trans tunnel to suit the VN trans which I will post some more photos when its all trimmed up and the box is in place
Posted on: 2007/10/8 13:03
Peter Brock
From Perth WA
God damn that is such a good fit! Minimal mods to the sump too! How much bigger do you have to make the trans tunnel? And how are you gonna strengthen the whole thing so it doesnt just twist in half?
Posted on: 2007/10/8 13:15
Chris...
From Adelaide, Australia
Looks like you've been busy Adam!
Took me a while to register it was you on sth road the other day, I had been painting the unit from midnight and was half asleep!
Posted on: 2007/10/8 13:16
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Adelaide. SA
I plan to use the commodore tunnel (well some of it anyway). and will stitch weld the seams and have some sort of half cage in it. Its all fitting a lot better than I had expected.
Cheers. Adam.
Posted on: 2007/10/8 22:26
Peter Brock
From Brisbane, Australia
What if you swap the manifold so they are pointing up? Would you run twin stacks or twin high mounts?
Posted on: 2007/10/8 23:15
From Adelaide. SA
I did think of that but the manifolds are not symmetrical so custom jobbies are the go. have thought of the twin turbo set up too but funnily enough ive run out of room
Posted on: 2007/10/8 23:24
Peter Brock
« 1 (2) 3 »
