Re: building a 1000 coupe
From perth airport
thanks im enjoyin working on it and when theres hardly any rust it makes it so ezy ... i was reading mr1600 build up thread on ozdat and the amount of welding hes done would drive me insane
anyway got a full day of working on the car to morro :)
hope some one gets the lil sister bak on the road agen :)
on a side note mals motoring are selling a sand blaster would it make my life ezyer or is the wire wheel the way to go ?
Posted on: 2007/10/13 13:08
perth airport parking
Datsun 1200 ute A14
From perth airport
been buzy with fixing some rust in the chassie but with a old hydo fan helpin me breath ( dam gassless migs ) shes all good and in primer
looks way better now
soon the a15 will be turning up :)
and some fiberglass gards :)
im 99% shore it will be sky blue
Posted on: 2007/10/22 9:55
Datsun 1200 ute A14
From perth airport
bit of an update after seeing some coupes with out bumpers i have welded up the spots where the bumper was mounted and boged it up looks good ill post a pic when its in primer
as for the drive line it will be a a15 wit a 5 speed box im hopeing the diff will be able to hold up as i plan to leave the original diff in .
Posted on: 2007/10/28 1:52
Datsun 1200 ute A14
From Perth WA
good luck! I blew a H145 up with a standard A15!
What 5spd are you using?
Posted on: 2007/10/28 3:40
Chris...
From Freo
Your all vandals.. be gentle with the 145..
I never broke one..
you should put a sedan apron on there if your going bumper free...
Posted on: 2007/10/28 3:49
A15 PSI Project Motor
'72 CB750k,
From perth airport
i got the 5 speed Toyota Dellow box of sidedraft and im thinkin about the front apron i have only welded up the rear atm
the a15 i got is ment to be pretty quick so i guess the 145 wont last too long hey chis did you just put a nother 145 in ?
Posted on: 2007/10/28 5:03
Datsun 1200 ute A14
From Perth WA
yeh depends how you drive really. i just threw another clapped out H145 in it. Thinking of getting that diff from your old black Hilux shortened Jorden. But i donno. Dont think im even going turbo anymore.
Posted on: 2007/10/28 5:42
Chris...
From perth airport
givin up on the turbo
ill wait for the diff to blow
Posted on: 2007/10/28 11:08
Datsun 1200 ute A14
From perth airport
ok just a update on the kb10 the back is all filled in and looking good heres a pic
im staying with the coupe front apron but i filled in two holes, looks better i think .
and heres a good pic of the gutter less look i like it makes it nice and smoth :)
Posted on: 2007/11/3 9:47
Datsun 1200 ute A14
From perth airport
the doors had some hard to get to rust so i had to pull em apart to sand blast & weld em im shore ill reget pullin them apart when it comes time to put back together but it had to be done
Posted on: 2007/11/3 10:07
Datsun 1200 ute A14
« 1 2 (3) 4 »
