wiring diagram?
Is there anyone who could lead me where to download a wiring diagram of the nissan ute?
Posted on: 2003/4/21 1:43
Re: wiring diagram?
From Stone Age somewhere in U.S.A.
I have 1 for a 71-73 if that wiil help
Posted on: 2003/4/21 5:18
Re: wiring diagram?
yes, please....my ute is "new" release (1989-91) but the 71-73 is the basis of this so I suppose it should work.
I did some "dumb re-wiring" on my ute and now I can't seem to figure out if I did some wrong connections in the distributor connections coz I can't make it work (starter is working but it just won't burn the fuel).
you could email it directly to me (if you can scan it) at my email: whyldthing@yahoo.com
thanks.
Posted on: 2003/4/21 13:09
Re: wiring diagram?
From Canberra, Australia
You sure that the pigtail lead on the back of the distributor is connected?
Posted on: 2003/4/21 14:10
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: wiring diagram?
wildthing, the newer wiring is very different from the 71-73. Even the 1975 was considerably different. For example they use ignition relay. Yours 1990 probaby has electronic ignition, which is wired in a different manner.
Is your ute a B122 or B140?
Posted on: 2003/4/21 17:16
Re: wiring diagram?
lobster, yes the pigtail is connected....all those I visually recall is connected
ddgonzal, this model came into the Philippines as a low-cost car and there is not much modification done...I don't think it have an ignition relay (although I don't know yet) and definitely not electronic ignition because it got the contact point...there is a possibility too that the wiring was modified by the previous owner/s...and I'm not sure what model is it called - it does have the A12 engine and the body of the later model ute (like the roadstar) but with a different grill and headlight (rectangular shape and not the round ones).
Posted on: 2003/4/22 0:00
Re: wiring diagram?
check your email, it's been sent
Posted on: 2003/4/22 8:35
Re: wiring diagram?
rgrinder,
thanks i got them.
Posted on: 2003/4/23 4:34
