« 1 (2) 3 4 5 ... 7 »
Re: mean a15
From gold coast
thats wot i need help on..... what are the pro's and con's of throwing cash into an a15
Posted on: 2007/10/17 7:30
Re: mean a15
From perth airport
well hears wat i can think of ...
a15 is keepin it sort of oringinal
a15 dont need a bigger gear box tunnel
but they have there limits in power
if you looking at ca18det hears a quick list diff, fule tank , brakes, shocks, all have to be upgraded but a ca18det will make 140 kw standard and there s a helll of a lot more power to be made if you want
Posted on: 2007/10/17 7:52
perth airport parking
Datsun 1200 ute A14
Re: mean a15
From Wagga Wagga, NSW
a15s are a great engine but arnt cheap to make decent figures out of an l series conversion is cheap and to make power out of and are a great engine and have the torque and they dont take a turbo to haul ass and dont weigh as much as a ca18det.
l series=cheap to put in 1200
=cheap to make decent figures out of
=sound great
=dont affect handeling much at all as everyone says
Posted on: 2007/10/17 7:55
Re: mean a15
From gold coast
well i am after a ruff list of things to do to get lets say 140-150 hp...its gota 2t/3t 5speed from dellow(was put in bye them) so drive line is fine...i thort of...a lumpy but practical cam,double valve springs,42mm dels,cold air intake,electroic dizzy,big ass radiator with termos....tony regoli performance rebuilt it but for sum WEIRD reason didnt go mad with their power addiction for once
Posted on: 2007/10/17 8:04
Re: mean a15
From gold coast
come on someone must hava sweet powerful a15
Posted on: 2007/10/17 10:42
Re: mean a15
Doyle, Andys engine is one of the best a15 going around, you are mad to pass it by. Knowing Andy he has spent probably more than what he has said as he is quite conservative in what he says to satisfy his sanity to his partner.
If I had a dellow t series setup just pop this in and enjoy it.
The 82mm stroke of the a15 is ideal in racing specially with the bigger bores he has done already, JTS and all the famous and successful racing big capacity a-series used the a15 crank. No N/A A-series will match the driveability and pull of an well tuned 1.6 ltr a15.
Posted on: 2007/10/17 21:54
Re: mean a15
From gold coast
well boys i just trying to get the olds to give in n give me $2300....it sounds lyk a sweet motor...i start hsc exams today so i hope the motor lasts till the 2nd of next month...if so then its mine lol
Posted on: 2007/10/17 23:16
Re: mean a15
From gold coast
well andys its gorn owell fone calls going out for parts for my motor now just a few questions...does anyone know much bout the a series heads from redline performance? also how much will twin 42mm dels set me back (brand new)?....ALSO how much can u safely bore out a a15 without a piston coming through the firewall when flogging it...cheers
Posted on: 2007/10/18 10:25
Re: mean a15
From Christchurch NZ
79mm
Posted on: 2007/10/18 21:17
Forced Induction!
Re: mean a15
not sure bout dels but brand new 45 webers 720ish each brand new
Posted on: 2007/10/18 22:32
