#1 help with e15et in 1000ute
Matto1kUte Posted on: 2007/10/14 11:55
i couldnt find much on this subject but i have put a 120y gearbox on to my e15et by using a vanette thrust bearing and carrier (little smaler in length) ive used the stock e15 flywheel and clutch and all looks to match up perfect. next i recon i have to dril a round hole in my fire wall to fit my dizzy. does anybody know if i will run into any other probs? i think i may also have to cut my utes engine mounts off :(. also does anybody know if a turbo off a
ca18 will fit straight on to my e15et manifold?
#2 Re: help with e15et in 1000ute
beattie Posted on: 2007/10/14 12:40
somebody put a thread up called 'food for thought' or something about fitting a E15(FWD) into a A series(RWD) engine bay. Looks like your gonna have alot of trouble with engine mounts! Have a search for the thread.
Good luck! and keep us posted!
#3 Re: help with e15et in 1000ute
Matto1kUte Posted on: 2007/10/14 12:58
as long as theres a thread around ill hold it up lol
#4 Re: help with e15et in 1000ute
gx1200 Posted on: 2007/10/17 1:08
Tnpshow started the thread on this. A CA turbo should bolt up to the standard manifold.
Cheers
#5 Re: help with e15et in 1000ute
TnPshow Posted on: 2007/10/17 1:24
Here it is
Might have to pull the finger out and chuck it in the wiki...
#6 Re: help with e15et in 1000ute
Matto1kUte Posted on: 2007/10/18 13:12
. what oil cooler? hopefully i will be droping this motor in this weekend. hopefully? i thk the fctory computer will be easy to wire up. i got the wiring diagrams of www.n12turbo.com
any i deas where to get a turbocharger of a ca or sr. a T25 i think in adelaide? oh yea does anybody know if i can use a e15 non turbo electronic dizzy on the et model?
#7 Re: help with e15et in 1000ute
Matto1kUte Posted on: 2007/10/22 11:23
hey guys just havin another prob. my bonnet wont shut by 2-3 inches. how can i get the e15 to fit under the 1000 bonnet? can i lower the crossmember? will it effect my steering ect?
#8 Re: help with e15et in 1000ute
beattie Posted on: 2007/10/22 12:06
Haha yeh thats the biggest drama with 1000 engine conversions. Height! You may have to go XR8 bonnet hump style! Or a scoop of some description. Doubt you could drop the X member, maybe a 10mm spacer?
#9 Re: help with e15et in 1000ute
Matto1kUte Posted on: 2007/10/23 11:51
does anybody know if there is a tailshaft the same as my 1000 one but 2-4 inches longer?also again does anybody know if drop my crosmember 1-2 inches if it will effect anything else such as steering and suspension. if not i may have to modify sump, rockercover and bonnet. i really really dont wanna put a scoop or anything on it
#10 Re: help with e15et in 1000ute
sr12 Posted on: 2007/10/23 11:59
could you not tilt the engine towards the passenger side slighty? should make it low enough, plus give more room for things like a brake booster
(1) 2 3 »
