r31 breaks
From brisbane, QLD
hi all does anyone no if you can put r31 breaks onto 1200 ute..
Posted on: 2007/10/18 12:55
Re: r31 breaks
From Coondle, WA Australia
pretty sure you cant..
bluebird ones are the go i believe
Posted on: 2007/10/18 13:29
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: r31 breaks
From Geelong, Vic
front or rear, both can be adapted one way or another
Posted on: 2007/10/19 3:23
Re: r31 breaks
Well yeah you can, with enough paitence and money pigdog, you can adapt anything.
as far as a direct swap... its the bluebird ones for the rear at least.
Posted on: 2007/10/19 4:05
Re: r31 breaks
R31 straight forward just need to make sure you have all the right parts. I think you need the stanza lower bit
the top of the struts the wholes need to be made larger from 8mm to 10mm
HAHAHAHAHAHA
thats what I was told.
months of stuffing around finally made them fit BUt the upside is I can do a front end in a 1200 in about 7 mins a side now LOL
Posted on: 2007/10/19 4:34
Don't You Just Love Owning a Road Registered GOKART
Re: r31 breaks
From Penrith, Sydney, NSW
Get a set of series one bluebird struts, then cut a 1200 spring perch off a set of standard 1200 struts and weld them onto the bluebird struts at the appropriate height for whatever 1200 springs your using. That way it will fit up into the tower.
Then the r31 discs and brakes bolt straight on.
All you will need to fit the bluey struts would be stanza lower control arms, tie rods, outer tie rod ends, steering arms and ball joints. Also use 120y radius rods and a 120y sway bar and your set!!!!
No easy bolt on way to do it to 1200 struts as far as i know.
Trav
Posted on: 2007/10/19 5:25
"If the doors of perception were cleansed, every thing would appear to man as it is......infinite"
