sr20 datsun 1000 ute
From sout east gold coast
will the sr20 motor fit into a standard 1000 ute engine bay? anyone seen this done before?
Posted on: 2007/10/20 0:16
Re: sr20 datsun 1000 ute
From perth airport
the sr20 would fit you will need a bigger gear box tunnel :)
Posted on: 2007/10/20 1:01
perth airport parking
Datsun 1200 ute A14
i thought so but that would be too much work huh, few steel supports here and a afew bits of stainless there.?
re-locatate the shifter. would mess up the wright distrabution tho
Posted on: 2007/10/20 1:07
From perth airport
putting a bigger gearbox tunnel is ezy but if you think it is hard i would recomend staying with the motor you have
Posted on: 2007/10/20 1:47
Datsun 1200 ute A14
much heavier and bigger than ca18de.
better suited to 1200.
Posted on: 2007/10/20 10:05
From Canberra, Australia
you should measure the height of a sr20 first before you just say you will need a bigger tunnel thats it!!!
The sr is 720mm tall, it will fit in a 1000 if you want the plenum and the whole rocker cover through the bonnet!!!
Posted on: 2007/10/20 10:15
From perth airport
Ok well, fyi i have actually measured the 1000 engine bay and i have measured an sr20 and it would fit without #### hanging out the bonnet
Posted on: 2007/10/20 10:23
Datsun 1200 ute A14
So tell me more champ, will it fit with an electric supercharger? What front suspenion will you use?
I have measured my SR20 and my 1000 engine bay. I even sat my SR20 into the engine bay. It will need a custom crossmember, a modified steering drag link and different spring arrangement and even then it will stll have a bump in the bonnet to clear the front of the plenum and the cam cover.
Posted on: 2007/10/20 13:28
Ignore that 'phunk' comment perthute.
It seems any young bloke without the benefit of experience is constantly going to be under fire. In this incident it is shrouded in sarcasm. I'm sure your measurements were recorded under your own basis of knowledge. I think what phunk means to say is that you haven't taken into account particular technical issues that would need specific attention.
Just agree and pay your respects to the aforementioned god of knowledge and king of sarcasm.
Posted on: 2007/10/20 17:46
I would just like to add;
Ignore that 'perthute' comment Datz_Ezza.
Its obvious he measured it to fit in a 4wd 1000. If it fits under the bonnet cleanly of a normal 1000, you will need to attach a trench digger to the front bumper so there is ground clearance for the gearbox bellhousing as you drive.
Just be humble and say thanks but no thanks for the advice.
Posted on: 2007/10/21 0:59
(1) 2 3 4 5 »
