« 1 (2) 3 4 5 »
Re: sr20 datsun 1000 ute
From perth airport
the question was will a sr20 fit ? NOT point out the obvious ( custom crossmeber ) what did you think it was gonna line up with the oringinal engin mounts ? and i had neva heard of a elictric super charger before nor would i use one your just tryin to be a keybord hero .
with the right crossmember it would fit with out #### hanging out the bonnet maybe it would need a slight bulge in the bonnet but nothing crazy
i dont know about you but im used to getting big things in small places
Posted on: 2007/10/21 1:43
perth airport parking
Datsun 1200 ute A14
Hahaa you are a crack up. Great advice, just leave out the all important parts that you forgot about.(Length-check, Width-check, Height- ohfuk.)
So why did you point out it will need a new tunnel?
Best of luck. I know its 2007 and that stuff might me the hip thing to do. But mine still reads EXIT ONLY.
Posted on: 2007/10/21 2:01
From perth airport
his question was will it fit well the gearbox wont fit so it will need a bigger tunnel the motor will fit eg the fire wall can stay ect ect if you change any motor there s a 99% chance the crossmember will have to change but i didnt wanna point out the obvious when he said welding a tunnel in was too hard i said putting a bigger gearbox tunnel is ezy but if you think it is hard i would recomend staying with the motor you have , But mine still reads EXIT ONLY thats not wat your dad told me fag you should join the pulsar club im shore youll fit in
Posted on: 2007/10/21 2:23
Datsun 1200 ute A14
From Tamworth , NSW
so,
phunks dad said yours doesent read 'exit only'???
do you really have to resort to names such as 'fag'?? how old are ya????
whatever happened to just duking it out??
Posted on: 2007/10/21 2:57
From perth airport
im 23 im shore punks is much older , goin on the amount of posts . but he should re think the way he replys to posts . being sarcastic and other words i cant spell dont help the site ...
so is anyone saying a sr20 wont fit in a datsun 1000 ??????????????????
how manny new comers put there first post ... will a ca18det fit in a datsun 1200 ???????????? the short answer is yes but youll need a bigger gearbox tunnel
ps i do plan on doing a 1000 sr20 later on not for road use
Posted on: 2007/10/21 3:18
Datsun 1200 ute A14
Plain and simply making pointless posts and giving advice about things you have no idea, dont help anyone.
I simply pointed this out buy asking you questions? My bad, but you still dont seem to have answers.
I didnt get involved untill you tried to shoot someone down and say it will fit under the bonnet. After all you have done your hands on research.
Custom crossmember is more than engine mounts champ. And a custom crossmember in a 1000 is a lot more involved than doing the same in a 1200.
My simple advice, be humble and say thanks but no thanks.
Posted on: 2007/10/21 3:33
From perth airport
Plain and simply making pointless posts and giving advice about things you have no idea, dont help anyone.. wat the! i have a 1000 i have a few sr20s are you saying it wont fit ?
I simply pointed this out buy asking you questions? wat where they ? was that when you asked wat springs should be used ? the guy asked would it fit not a list of stuff he will need. grow up
My bad, but you still dont seem to have answers? wat answers like will it fit ?
I didnt get involved untill you tried to shoot someone down and say it will fit under the bonnet . i didnt shoot him down he said you should measure the height of a sr20 first before you just say you will need a bigger tunnel thats it!!!
i pointed out that i had measured it
and i feel it would fit under the bonnet or it would need a slight bulge
After all you have done your hands on research ?? yea i have measured it and i think it will fit wats your point
i know it would be more involed than a 1200 one but that wasnt the question was it
Posted on: 2007/10/21 4:20
Datsun 1200 ute A14
Clyons8 wouldnt you prefer to have some sarcasm thrown your way rather than spending money on failures? Life is too short to be pampering the wool of the boring herd. This is what a forum is for to seperate the crap from our hobbies.
Its better to listen to the advice of those who have been here for a while and have done it even if some fire is blown your way.
I dont how else to help so many sunburnt scalps with the same idea, Phunk has tried and others have tried to put an sr20 in a 1k engine bay just to see whats needed to be done.
I regretted the plan as soon as I found out they are heavier than a ca18 and larger, defeating what the 1k stands for light and nimble not nose heavy.
You always get noobs or bogons saying to put in a v8 or an almost equally heavy engine like the sr20det into a 1k or a mini or some other sheep sugestion. Just because its alloy it doesnt mean its light and compact - the thing is thickly sand cast and designed for big heavy sedans! modern 2ltr twin cam engines weight 50kg less by using pressure die casting. These modern light alloy 2ltr engines are more suitable for K konversions..
Again plain and simple its too long and too tall for a 1k engine bay. Unless you spend 2 to 3k on a custom front end/crossmember and run a dry sump setup as the sump will hit the ground once you lower a 1k to make it handle and marginally at that.
A much heavier car with an sr20 will outhandle and outrun a crippled sr20 b10 anyday.
Why do you think Steve Newing's c18de stanza beat lighter cars with sr20de and great drivers consistently? Its not just the donk that makes the project worthwhile but well balanced, well engineered setup.
Always think of what a car deserves, listen to people who have sound advice even sarcasm and work towards a car that wont just be a lead tiped arrow. There are too many already.
Posted on: 2007/10/21 6:28
From Canberra, Australia
A merlin jet engine will fit Christ anything will fit but will it be practical and achievable and drivable and registrable??? These are all questions that need to be answered not simply yeah it will fit, custom cross member and new tunnel!!!
If you have sr20's you can simply look at the motor and know there is no way that will fit in a 1000 and the bonnet actually close.
Back to the original post, a hottie a15 or a, dare I sa it, 4age or gze would be the go and about the biggest motor you could get in these cars. Besides everything that has been said you will not get an sr20 engineered in a b10.
I have fitted many different motors to many different datsuns over the years, I am not offering my advice as a way of shutting down someone else's enthusiasm, its facts of the matter
Posted on: 2007/10/21 7:02
D I understand and take into account what you have said. Some very appropriate, notable words.
As a newbie I spend most of my web time browsing and reading rather than posting and questioning (I prefer to try and find my answers).
As I have observed in my pursuit for knowledge it appears that phunk tends to use this very derogative and condescending manner of conversation. And as I read back on the thread I think it is fair to say that phunk has once again produced one of his specials.
Now I understand that newbie's should expect to cop some 'resistance' just like the new kid on the block scenario however, I do think that the typical rules of polite mutual treatment that would perhaps apply in the physical realm ought to be equally satisfied on webspace.
The older members here must understand that the newbie
Posted on: 2007/10/21 9:09
« 1 (2) 3 4 5 »
