steering rod
From Burpengary
does anyone know what, if any, other steering rods will fit a 1985 datsun 1200 ute?
Posted on: 2007/10/20 12:26
Re: steering rod
Is THIS
the part you want? Some sat Nissan still has them in stock.
Posted on: 2007/10/20 13:42
Re: steering rod
Any 1978-1985 steering rod, if you mean the cross rod (center drag link).
steering components
If you need the side rods, those might interchange with B210.
Posted on: 2007/10/20 17:21
Re: steering rod
From Burpengary
nah the bit the steering wheel bolts to. is it called something else
Posted on: 2007/10/21 3:37
Re: steering rod
Steering column? all 1200's will fit, just the later model ones are collapseable in an accident.
Posted on: 2007/10/21 3:43
Re: steering rod
From Quairading, Western Australia
steering column, pitman arm?
Re: steering rod
From Burpengary
steering column it is! you guys rock, sorry, i had a total brain fart then.
so other than the 1200's, what others will fit? does anyone know of any other steering systems that will fit into the 1200 ute?
Posted on: 2007/10/21 3:51
Re: steering rod
no others will fit
Posted on: 2007/10/21 4:52
Re: steering rod
From Burpengary
ok that's cool, now i know! Thanks for your help
Posted on: 2007/10/21 6:24
