#1 door problems
dumpedute Posted on: 2003/4/23 6:04
hey guys,
recently the passenger side window on my 1200ute stopped winding all the way up .... and the door lock wouldnt go up and down , just stays up ...
when i took for the door upholstry off , the metal bracket on the bottom of the window that holds it in place was sitting in the bottom of the door and half of it is rusted away.....
not sure if you know what bit im talkin bout but anyway, can you get these from wreckers or what??
cause at the moment ive just got it sitting in place with the window up .... but the door lock still doesnt work (another problem , its like the switch has ceased or something , caused it wont lock and unlock) dramas i tell you dramas.....
any ideas?
#2 Re: door problems
ddgonzal Posted on: 2003/4/23 7:04
There is a metal channel that the window glass is pressed into ... if you find a broken window at the wreckers they'll probably sell it cheap. Otherwise they usually like to sell the whole window.
#3 Re: door problems
dumpedute Posted on: 2003/4/23 7:23
yep thats the bracket im talkin about...!
easy to get???
any ideas on the actual ldoor lock not moving up or down..... had this problem before??
#4 Re: door problems
Buff Posted on: 2003/4/23 7:57
if the key actually turns around in the barrel but the lock doesnt move i presume one of the rods has come off inside the door.
If the key doesnt turn it sounds like something has jammed or seized.
Its usually easy enough to fix just sometimes a bit of a fiddly job.
Get a decent light up inside the door skin and have a look - if necessary take the other door trim off and compare the two to see whats happened.
It can't be anything to serious.
#5 Re: door problems
dumpedute Posted on: 2003/4/23 9:07
nah cant anything serious famous last words .... hehehe'
yeah i'll compare to the other door..... thanks guys
