i have been playing around with this idea for a little while. i got one possibility of it working. my therory is that if the intercooler is up higher than the rest of the intake pipe work than fuel will not condense and build up in the cooler. however fuel may condence and build in the pipework after the cooler. in order to do this you need a rather small cooler and lay it flat. down side is that it will get alot of heatsoak from being inside the engine bay. its just an idea i have been playing around with i havent had the chance to finish it as i i have run out of funds and i still need to fix or replace my existing turbo. dont how well this will work or if it will work at all
other things to consider are lots or heat sheilding, small themo fan to draw cold air from down low and blow it out through the bonnet and also the hole in the bonnet
i can uplaod some picks if anybody is interested in what im trying to do but again i dont no if it is really worth doing
