steering play? WHY?
From Newcastle
i was playing with the steering box and now it has like a full turn of play b4 she turnes the wheels? tryed the adjuster screw in the top and nothing can some 1 help and give me some idea
Posted on: 2007/10/31 4:23
Re: steering play? WHY?
From perth airport
wat did you play wit ? i pulled mine apart and put it bak together and theres the screw to take the slack out other than that i cant think of much elce except u might of unscrewed it ?
Posted on: 2007/10/31 5:02
perth airport parking
Datsun 1200 ute A14
From South Africa, Bloemfontein
You will have to be more precise with your description. What exactly,step by step, did you do?
Posted on: 2007/10/31 5:36
1977 Datsun 1200GX
From Geelong, Vic
do you do the nut up that holds the steering column to the steering box properly?
i had a 180b that had no splines left on the input of the steering box so it had a good half a turn before the bolt holding the column to it jammed and started the car turning
was kinda scary to drive
Posted on: 2007/10/31 5:37
Looks like you don't have a workshop manual. These are very helpfull when working on things that you are not familiar with. Highly recomended.
Posted on: 2007/10/31 5:53
Love your Datsun.
Treat it well.
From Newcastle
i undid the 4 bolts on the top and tryed to pull the colloum out but couldnt do it then put it back in and this has happened
Posted on: 2007/10/31 11:17
From perth airport
arrr its very hard to explane but i would say you need to undo the nut under the steering box and then you can locate it ( the weird sharft ) sorry dont know wat its called but if you undo the nut under the box and pulll it apart you see how it works :) i was it you sercamstance not long ago i should get a 1200 manaul
Posted on: 2007/10/31 11:27
Datsun 1200 ute A14
From Newcastle
so u think i should remove the bottom and have a look ? i got no idea how it works or where to start. . any pic would be helpful i havnt got any?
Posted on: 2007/10/31 11:29
From perth airport
sorry i didnt take any pic
Posted on: 2007/10/31 11:34
Datsun 1200 ute A14
From Sydney, Australia
if you pull (then jiggle) the steering column apart without removing the pitman arm, then you need to pull it all apart and read the factory service manual.
You can't easily disassemble and reassemble it, because it doesn't matter how careful you are during reassembly, the bottom bearing gets pushed out of position, and basically is now rattling inside the steering box.
I know I'm right. Been there...done that.
Posted on: 2007/10/31 11:58
(1) 2 3 »
