Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
steering play? WHY?
Laney
Posted on: 2007/10/31 4:23
i was playing with the steering box and now it has like a full turn of play b4 she turnes the wheels? tryed the adjuster screw in the top and nothing can some 1 help and give me some idea
#2
Re: steering play? WHY?
perthute
Posted on: 2007/10/31 5:02
wat did you play wit ? i pulled mine apart and put it bak together and theres the screw to take the slack out other than that i cant think of much elce except u might of unscrewed it ?
#3
1200GXman
Posted on: 2007/10/31 5:36
You will have to be more precise with your description. What exactly,step by step, did you do?
#4
PIGDOG
Posted on: 2007/10/31 5:37
do you do the nut up that holds the steering column to the steering box properly?
i had a 180b that had no splines left on the input of the steering box so it had a good half a turn before the bolt holding the column to it jammed and started the car turning was kinda scary to drive
#5
Dodgeman
Posted on: 2007/10/31 5:53
Looks like you don't have a workshop manual. These are very helpfull when working on things that you are not familiar with. Highly recomended.
#6
Laney
Posted on: 2007/10/31 11:17
i undid the 4 bolts on the top and tryed to pull the colloum out but couldnt do it then put it back in and this has happened
#7
perthute
Posted on: 2007/10/31 11:27
arrr its very hard to explane but i would say you need to undo the nut under the steering box and then you can locate it ( the weird sharft ) sorry dont know wat its called but if you undo the nut under the box and pulll it apart you see how it works :) i was it you sercamstance not long ago i should get a 1200 manaul
#8
Laney
Posted on: 2007/10/31 11:29
so u think i should remove the bottom and have a look ? i got no idea how it works or where to start. . any pic would be helpful i havnt got any?
#10
dattodude
Posted on: 2007/10/31 11:58
if you pull (then jiggle) the steering column apart without removing the pitman arm, then you need to pull it all apart and read the factory service manual.
You can't easily disassemble and reassemble it, because it doesn't matter how careful you are during reassembly, the bottom bearing gets pushed out of position, and basically is now rattling inside the steering box. I know I'm right. Been there...done that. You can view topic.
