Re: does the 120y swaybar clear the ca18det sump. . MINE Doesnt? help
From brisbane
Exactly Andrew. My custom bar is the same diameter as the factory 1200 one. If it works why change it?
Matty
Posted on: 2007/11/3 21:15
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Geelong, Vic
but then when you make up a 1 inch one for free....what do you have to loose?
Posted on: 2007/11/4 2:22
From Mudgee NSW Australia
Hi Andrew, do you mean the standard 1200 one or 120y?
I used the standard 1200 swaybar. Im not sure on the differcence between 120Y though a little thicker and maybe different shape.
Cheers Andrew
Posted on: 2007/11/4 4:39
If In doubt run more BOOST
From SE Melbourne
The reason why it clears is that the front of engine sits 30mm lower (recessed crossmember) so engine can sit further back the engine /gearbox is on less of an angle so the whole setup sits around 15-20m further back.
I found the standard swaybar more than upto the task!!! with good struts and a brace they do most the susspension work. Why go bigger if not really needed??
Cheers Andrew
I must admit it does sit lower and pretty much on the firewall...Im pretty sure my coupe has got a 120Y swaybar in at the moment too...
Posted on: 2007/11/4 9:33
Mildman, Datsunless
From Canberra
I went bigger (to 20mm) because it's no longer a standard bar, the extra length added to clear the sump reduces the stiffness of the bar therefore you need to compensate by increasing the diameter.
But i agree if you can fit a standard bar then don't bother with increasing the size.
Posted on: 2007/11/4 11:04
« 1 2 (3)
