How to set up surge tank for a ca18det in 1200 ute
From Adelaide
Hey guys..
im after sum advice, for the surge tank set up
i no the buttom hose of the surge tank is to the engine,middle is to lifter, top hose is return and top top is overflow to the tank..
but do people use that big box in the side of the tray still? or do u disconnect the lines from it and use on the surge tank?
and does the overflow one just go straight to the top of the tank with a T piece?
cheers, Ben
Posted on: 2007/11/6 7:42
Re: How tp set up surge tank for a ca18det in 1200 ute
From campbelltown (sydney) australia
dont know what box u mean but u set it up how u said im wanting to know about the tee piece for the return i just wonder whether the teeing of the fuel rail return will back up with fuel or anything like that coz i wanna do the same thing. maybe a one way valve could make this work.
Posted on: 2007/11/6 9:00
* caution, sunglasses must be worn to view my ca18det *
From Adelaide
THIS is prob a stupid question but,
do u have to use a reducer thiing to inlarge the hose from the fuel tank to the surge tank? im using 3/8 line and the one from ther tank would be like hmm tiny lol
Posted on: 2007/11/6 11:30
From Adelaide
I normally pull all the small return type tank out from the right hand guard.
With the surge tank, they can be plumbed a couple of ways. Bottom efi feed, Top pipe is return to tank, Next down is return from engine, third down is fill from tank with low pressure pump.
The other way is to run the top back to tank, second one down is the low pressure fill, and very bottom is the High pressure efi. But the return from the engine goes straight to the main tank, as the fuel is now warm from being pumped through two pumps at pressure and fed into a warm fuel rail. And if this warm fuel keeps getting added to the surge tank, it slowly brings temp of all the fuel in the surge.
Posted on: 2007/11/6 11:34
From Adelaide
Crzy, yes you will have to use a expander/reducer as the lines on the tank are 1/4 inch.
Posted on: 2007/11/6 11:36
From Adelaide
oh ok.. i might aswell run it back to the tank as the line is already there..
so how would i block the top whole on the surge tank then? ideas..
Posted on: 2007/11/6 11:39
a threaded plug ??? easy
Posted on: 2007/11/9 8:47
