#1 anybody got a flywheel tension spec for the A15
woody Posted on: 2007/11/7 2:53
im after the torque for the bolts for the A15 flywheel, and i cant find anything in the wiki.
any help would be appreciated
cheers kurt
#2 Re: anybody got a flywheel tension spec for the A15
Ronald Posted on: 2007/11/7 2:58
88Nm or in other words rattle gun.
put some thread lubricant on them before you do them up too.
#3 Re: anybody got a flywheel tension spec for the A15
woody Posted on: 2007/11/7 3:02
yeah got the locktight ready. 88nm isnt that much? and do you have to tighten it in stages, ie 40nm first then 88nm?
and do you think having one less dowel pressure plate holder will effect the thing at 8000rpm? "(its a race engine)
thanks ronald for that
#4 Re: anybody got a flywheel tension spec for the A15
Mildman Posted on: 2007/11/7 6:30
If your keen you could put all of these figures in the wiki.....anyone can enter info.
TORQUE WRENCH SETTINGS
Cylinder head bolts . . . . . . . . . . . . . . . . . . . . . . . . . 74 Nm
Connecting rod nuts . . . . . . . . . . . . . . . . . . . . . . . . 37 Nm
Flywheel bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88 Nm
Main bearing cap bolts . . . . . . . . . . . . . . . . . . . . . . 59 Nm
Camshaft sprocket ......................... 47 Nm
Camshaft locating plate . . . . . . . . . . . . . . . . . . . . . . 8 Nm
Sump bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Nm
Oil strainer bolts ........................... 14 Nm
Crankshaft pulley bolt . . . . . . . . . . . . . . . . . . . . . 196 Nm
Timing chain cover bolts . . . . . . . . . . . . . . . . . . . . . 7 Nm
Rocker pedestal bolts . . . . . . . . . . . . . . . . . . . . . . . 25 Nm
Valve rocker adjusting nut . . . . . . . . . . . . . . . . . . . 22 Nm
Sumpplug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 Nm
