Re: Pixs of my S13Brake/susp to 1200 Coupe conversion
Quite a regular
From Christchurch
how much wider is the track with the s13 control arms ??
Posted on: 2007/11/5 23:31
more than an hand full is a waste give me bigger hands :)
Ute rebuild
From Tannum Sands Qld
Heres some more pics. Here you can see the Toe adjustor machined down on the outside(S13 end).
Sorry havent had a chance to take wheels off pics, Its still raining plus i have a Supra in my shed thats getting worked on atm.
Posted on: 2007/11/6 2:36
To answer what the offset questions
Disc face to Disc face is approx 1390mm
Posted on: 2007/11/6 3:58
same with my settings as i have posted here before, but my car is B310
Posted on: 2007/11/6 6:41
From Townsville, Qld
That was helpful guys, but just to clear some things up Im going to see if I can find a silvia with standard brakes to try one of my wheels on.
Posted on: 2007/11/6 9:07
the wheels I was hoping would fir this setup dont( my 13x6 Cheviot Hulsters), they might if you were running nice chunky spacers (about 10mm+ min). The corners of the brake calliper and the top of the brake calliper hit. If you grinded taht area back about 10mm or so it may clear but that seems more than unsafe as the brakes are so thick for a reason
Posted on: 2007/11/7 12:55
From Okinawa, Japan
I tried my 13X7 Work Equip wheels and they fit. But, nobody else runs those rims so that's probably totally useless info...
Posted on: 2007/11/7 13:30
just now i saw one Nissan Vanette running on Work Equip 14"
Posted on: 2007/11/7 15:22
Update on this old thread. My hustlers do fit over S13 brakes, just not over the larger 280mm ones from SR engined S13s
Posted on: 2009/7/27 6:10
From Sydney
In the pics the rotors are fitted the wrong way. Witht eh way thety are currently mounted the brake dust and heat willl flow towards the center rather than [the preferred] out. Easy enough to fix though.
Edit. very confusing, Some pics have the rotors in the right way and some they are not.
Posted on: 2009/7/27 6:23
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
« 1 2 (3) 4 »
