« 1 2 (3)
Re: help with e15et in 1000ute
From Adelaide, Australia
problem solverd. i used a stock non turbo rockercover and it fit. i also spent $40 getting engine mounts made and i had to cut a hole on the firewall to fit the dizzy in wich i didnt like doing. i had to use a vl throttle body aswell which is a upgrade anyway.
Posted on: 2007/11/11 2:49
Is'nt there a distributorless ignition that could work inplace of having the distributor stick through the firewall? maybe megasquirt's ecu and Fords crank triggerd ignition? just food for thought>
Posted on: 2007/11/11 8:01
« 1 2 (3)
