hey all,
PLEASE NOTE: engine can be seen running. i won't be pulling it out until the end of November (after exams) so until then it'll still be in the car.
Engine is currently in a series 3 bluebird
Engine is complete ( all manifolds, turbo etc.) and is best suited for someone wanting to do an SR conversion in an older car. it doesnt have the power steering or air con pumps, and the loom has been modified for "plug n play", makes it VERY easy to wire into any car.
engine and gearbox are in top condition.
doesn't blow any smoke or steam, doesnt go through any oil or water and gets virtually no blow-by.
compression tests are welcome, when i bought it (bout two years ago) it was good across all cylinders.
made 179kw on ~14psi (have dyno sheets)
ITEM:
Red Top SR20DET
5-speed SR gearbox
Peter Liebig modified Loom
Stock SR20 ECU
REASON FOR SELLING:
car was written off, so parting it out.
PRICE AND PRICE CONDITIONS:
$3000ono
EXTRA INFO:
other parts include:
Xtreme cushioned ceramic clutch
Remote oil filter
Braided turbo oil/water feed lines
Speco 2" electric oil pressure gauge (sender is mounted in original oil pressure sensor hole)
Tomei copy 3" dump pipe
Shortened top water pipe
when i got it, i put in new spark plugs (platinums) and a new water pump (genuine nissan)
CONTACT DETAILScan call me on 0433 282 553
or send me a private message
