Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
ANY BODY ??
FRKYCA
Posted on: 2007/11/14 7:29
is ant body wrecking a 1200 ute or sedan in sydney , i need the front brake line (left and right)...
thankx
#2
Re: ANY BODY ??
COUP1200
Posted on: 2007/11/14 8:35
if you go to a brake & clutch shop you will get them made for you.
My advice is dont stuff around with second hand ones
#3
Re: ANY BODY ??
beattie
Posted on: 2007/11/14 9:28
ill second that!
Unless the shop needs samples.
#4
Re: ANY BODY ??
FRKYCA
Posted on: 2007/11/14 9:43
true, do you know how much i would be looking at.. and would they need sample,coz i dont have any...
#5
Re: ANY BODY ??
wagon1200
Posted on: 2007/11/15 8:58
I've made a few samples out of wire coat hangers ;)
#6
Re: ANY BODY ??
clyons8
Posted on: 2007/11/15 9:13
Well all that is done is the making of a bell end one either end of the piping couple of threads/bolts on each piece and some bending.
Do you need the bits that go between the two cylinders (drum brakes) or the bits from master to slave cylinders, so short bits or long bits? If it's the short bits then take the backing plate(which the cylinders are bolted to) to the shop and they'll figure the profile. For the long bits, bend some wire to the right profile and take that in. Alternatively: The pipng is relatively malleable so you can get a length and bend it (slowly and gently) to the right profile then take it in to get the ends sorted. Best option is to get them to do it. It shouldn't be too pricey. You can view topic.
