balljoint removal
From wangaratta vic australia
just wondering how hard it would be to replace the ball joint boots on my 120y,i ask now just in case ive bitten off more than i can chew,any help would be great!
Posted on: 2007/11/14 10:36
Re: balljoint removal
From Sydney, Australia
at $30 each..hardly worth buying new boots, but at $20 cheaper to just buy the boot, I guess if it's in good nick should be 5 bolts on each side. You'll need socket set, and maybe a can of WD40 to loosen the bolts.
Posted on: 2007/11/14 10:49
From melbourne VIC
The ball joint is connected with a tappered bolt that can be a real pain to remove.
I would suggest that you buy a ball joint removing tool, thats what i needed to do because mine were stuck tight.
Or you could just hit it with a hammer!
Posted on: 2007/11/14 10:55
balljoint is at the base of the strut. 2 bolts into the strut, and 3 into the lower arm ....
Or is the 120y/1200 one different. I have been driving a modified 1200 for too long...
Posted on: 2007/11/14 11:05
From Tamworth , NSW
to remove the balljoints 3 or 4 bolts that hold it to the lower control arm and the 2 that hold it to the bottom of the strut.
16mm i think.
i would not reccomend hitting any of the tapered doovers out with a hammer at all.
buy a proper tool.
Posted on: 2007/11/14 11:12
thanx for the tip im guna have a go at it,whats the worst that could happen?
Posted on: 2007/11/14 11:13
From Tamworth , NSW
dont forget to pull out the grease gun and fill em up with grease.
Posted on: 2007/11/14 11:14
another question
ive looked around for a new master clynder, and would u belive i cant find one! would u know of any one that might have one for sale? i think i need a new one when i put my foot on the brake it slowly sinks to the floor.
Posted on: 2007/11/14 11:18
Re: another question
From Tamworth , NSW
i dont have a spare, but surely one of the lads here will have one spare they may wanna part with.
Posted on: 2007/11/14 11:21
From South Africa, Bloemfontein
I replaced my one balljoint's rubber a while ago.Was cheaper than buying a new balljoint.
Just buy a balljoint puller.Very cheap.I once saw how they remove them with a hammer.Almost got a heart attack.
You will quickly figure out how and where to use the puller.If not, just consult a mechanic to show you.
Posted on: 2007/11/14 11:26
1977 Datsun 1200GX
