#1 balljoint removal
spark79 Posted on: 2007/11/14 10:36
just wondering how hard it would be to replace the ball joint boots on my 120y,i ask now just in case ive bitten off more than i can chew,any help would be great!
#2 Re: balljoint removal
dattodude Posted on: 2007/11/14 10:49
at $30 each..hardly worth buying new boots, but at $20 cheaper to just buy the boot, I guess if it's in good nick should be 5 bolts on each side. You'll need socket set, and maybe a can of WD40 to loosen the bolts.
#3 Re: balljoint removal
gino_120y Posted on: 2007/11/14 10:55
The ball joint is connected with a tappered bolt that can be a real pain to remove.
I would suggest that you buy a ball joint removing tool, thats what i needed to do because mine were stuck tight.
Or you could just hit it with a hammer!
#4 Re: balljoint removal
dattodude Posted on: 2007/11/14 11:05
balljoint is at the base of the strut. 2 bolts into the strut, and 3 into the lower arm ....
Or is the 120y/1200 one different. I have been driving a modified 1200 for too long...
#5 Re: balljoint removal
pepper Posted on: 2007/11/14 11:12
to remove the balljoints 3 or 4 bolts that hold it to the lower control arm and the 2 that hold it to the bottom of the strut.
16mm i think.
i would not reccomend hitting any of the tapered doovers out with a hammer at all.
buy a proper tool.
#6 Re: balljoint removal
spark79 Posted on: 2007/11/14 11:13
thanx for the tip im guna have a go at it,whats the worst that could happen?
#7 Re: balljoint removal
pepper Posted on: 2007/11/14 11:14
dont forget to pull out the grease gun and fill em up with grease.
#8 another question
spark79 Posted on: 2007/11/14 11:18
ive looked around for a new master clynder, and would u belive i cant find one! would u know of any one that might have one for sale? i think i need a new one when i put my foot on the brake it slowly sinks to the floor.
#9 Re: another question
pepper Posted on: 2007/11/14 11:21
i dont have a spare, but surely one of the lads here will have one spare they may wanna part with.
#10 Re: another question
1200GXman Posted on: 2007/11/14 11:26
I replaced my one balljoint's rubber a while ago.Was cheaper than buying a new balljoint.
Just buy a balljoint puller.Very cheap.I once saw how they remove them with a hammer.Almost got a heart attack.
You will quickly figure out how and where to use the puller.If not, just consult a mechanic to show you.
