Re: a15 twin carb engine trouble
From Wamboin near ACT(canberra)
i still have the socks, theres way less oil in them, The reason i couldnt figure it out, was because i took the first barrel sock of and nothing improved, so i didnt bother taking the rest of. yea its quite tight in the bay, i dunno why??, maybe diffrent manifolds. also is it common for the carbies 2 backfire a heap after tuning, its only when you back of the gas and slow down
Posted on: 2007/11/15 19:16
From The garage, NZ
just a thought...
possible needles seats not sealing? not a proper flow of fuel?
Might pay just just give em a check see
Posted on: 2007/11/15 20:16
From Sydney
When the Weber sidedraught carbies backfire, it typically indicates a lean mixture condition. Twin carbs out of sync can also behave in a similar fashion.
Posted on: 2007/11/16 0:35
From NZ
Shouldn't be backfiring and certainly not after a tune. As said above could indicate lean mixture. If just at idle/light throttle opening may just need to open up the idle screws a little - really should have been right when leaving the mechanic who fiddled with it. If carbs are out of balance will be idling rough. Also check timing.
Posted on: 2007/11/16 10:20
Quite a regular
From Perth, WA
im having the exact same trouble, although with a dead stock a12. ive tried everything as well. its doing my head in as i have to drive up a mean ass hill to get home everyday.
under load it like - dedededededededededededeed, bang bang, deddededeeededddededededededed bang. and big loss of power. sometimes i manage to get home......
Posted on: 2010/7/31 0:27
That sound is normally associated with carburetor synchronisation (or in your instance, severe lack of).
Balance your carbs.
Jetting issues are typically associated with popping, carb-backfiring and hesitation or 'bogging' sounds.
Posted on: 2010/7/31 0:45
LOL.
Bogging sounds...... you carby people know what i mean!
Posted on: 2010/7/31 1:06
« 1 2 3 (4)
