Dellow Engineering
Not too shy to talk
From Featherston, New Zealand
Any one have the contact details for Dellow Engineering please?
Posted on: 2003/4/27 9:28
Re: Dellow Engineering
From Invercargill, New Zealand
Hi BigJase,
Good shot of the Sunny in action. The contact details for Dellow Engineering are Sydney (02) 9774 3873 . Prices for the bell housing are around Au $595. You then need to source a 2T or 3T Toyota box, prop shaft conversion and suitable clutch in NZ - cheaper than they are here. You can get some good aftermarket ratios if required but you'll find the standard ones a good improvement over the Datto. The boxes are strong as - will take all the abuse an A series can dish out. I would expect you could put one together for under/around NZ 1k.
Posted on: 2003/4/27 10:42
There is more contact information for Dellow in the Tech Section article 5-speed Overview .
Posted on: 2003/4/27 17:41
Not too shy to talk
Thanks Guys.
Posted on: 2003/4/27 22:09
