#1 got a bad miss
spark79 Posted on: 2007/11/18 9:40
im in dire straights,ive just fitted my reco clynder head,new valves,stem seals,rocker arm,machined,i torqured down the head and rocker arm, and the engine has a miss like its running on 3 clynders,it was running smooth as b4 i put the reco head on. can some one help me plz. this has cost me lots of money,and i dont wont to ruin it. cheers mark!
#2 Re: got a bad miss
beattie Posted on: 2007/11/18 10:00
what is your ignition system like? Are you running new plugs? Did you drop any? What are your leads/dizzy cap like? Do a comp test to eliminate your head
#3 Re: got a bad miss
Dundee1000 Posted on: 2007/11/18 10:01
Adjust the tappets..
#4 Re: got a bad miss
perthute Posted on: 2007/11/18 10:01
while its running pull one spark pulg lead at a time if it runs the same then its a lead or spark plug ,
or a manifoild leak to test this spray wd40 over the manifold while running if it runns better theres your problem
or carbie probs
#5 Re: got a bad miss
beattie Posted on: 2007/11/18 10:28
a carby prob wouldnt make a miss, just a rough idle. A air leak may if its MASSIVE but usualy just makes it hunt or high idle.
Mike may be on the money about the tappits!
#6 Re: got a bad miss
spark79 Posted on: 2007/11/18 11:35
u guys mite be rite, can u tell me or show me threw pics on how this is done, sorry to sound like a dumb arse,i checked for manifold leaks and it made no difrence,it just runs like ####. thanx for helping lads.
#7 Re: got a bad miss
perthute Posted on: 2007/11/18 11:43
did you take one leed off at a time ?
you would wanna get a workshop manaul for the tappets
#8 Re: got a bad miss
spark79 Posted on: 2007/11/18 11:46
yeah bloke, took each lead of made no diffrence,i'll adjust the tappets and let you guys know how i go . cheers for help.
#9 Re: got a bad miss
ddgonzal Posted on: 2007/11/18 21:10
http://wiki.datsun1200.com/index.php/Valve_Adjustment
Get a Gregory's or something for more details.
If you don't adjust the valves after installing a head -- it WILL be off tune badly.
