« 1 (2)
Re: CG13DE / CGA3DE + SR20 gearbox?
You can ditch all wiring ecu and run a weber manifold with alloy tubular plenum, cheap throttle body for LPG and boost. LPG bits are cheap to source and if you want later you can go for the 61g accident proof kiwi made rectangular alloy LPG tank.
Posted on: 2007/11/15 5:11
From Sydney
well hopefully sss can find me one they are in japan looking for one atm and it should cost around 1500 incuding wiring etc
Posted on: 2007/11/18 9:22
Why 1500 from japan when you can buy one from here at the wreckers for less?
I would also consider the compact sized tiida 1.6 engine.
Posted on: 2007/11/18 14:32
From Central Vic
Have taken a different path now so wont be making adaptor plate. it was what i had been looking at only
would have been nice though
Posted on: 2007/11/19 2:01
to buy or not to buy???? OK
This is the reason I have five coupes
From Sydney
i have been ringing around u cant get cga3de here only the cg13de most people said that they didnt bring the cga3de to australia
Posted on: 2007/11/19 10:08
« 1 (2)
