custom tailshaft question
Not too shy to talk
I have a 1200 ute fitted with a ca18det, standard ca manual gearbox and stock h165 diff. Was told today that a datsun stanza manual tailshaft once simply shortened will fit in perfect both ends, does anyone know if this is true?
Posted on: 2007/11/29 9:54
Re: custom tailshaft question
From Melbourne AUS
stanza tailshaft is definately a good candidate for shortening for your application.
im almost certain that you'd have to change the gearbox end yoke to suit the ca box when shortening though..
Posted on: 2007/11/29 9:58
1973 B110 A12
Not too shy to talk
What about a s13 yoke on the 1200 stock tailshaft shortened ? to weak ?
Posted on: 2007/11/29 10:15
From Geelong, Vic
you could just get the s13 end welded onto the ute tailshaft, it will be just as strong as a stanza one.....but then your wasting a good ute tailshaft
Posted on: 2007/11/29 10:24
From Melbourne AUS
i used a stanza shaft in my ute for 2 reasons, becuase it had a bigger diameter tube and it also had replacable uni's which the ute shaft was lacking.
Posted on: 2007/11/29 10:34
1973 B110 A12
From Geelong, Vic
oh yeah thats right, it was only my superior ute tailshaft(now boofs superior tailshaft) that had replacable unis
bluebird ones are also a good base
Posted on: 2007/11/29 10:44
