A12GX block identification
Hi,
Is there any way to identify an A12GX block and cam by the casting numbers?
I've just pulled down my GX engine for a rebuild and noticed it has slightly dished pistons. I was under the impression they had flat tops. Do I have a standard bottom end?
Joel
Posted on: 2003/5/2 1:44
Re: A12GX block identification
From Brisbane Australia
Hi Joel, I have just had my GX engine rebiult,
I was told that all the bottom end is the same as std 1200 and the head was the same as a14
hope this helps
Ade
Posted on: 2003/5/2 15:03
The short block is more or less the same (so there probably are no special ID marks), but the cam and pistons should be different.
See the Tech Section article for details: Datsun A12GX Engine
Posted on: 2003/5/3 6:17
