diff problem
From Brisbane
I have this weird problem - when i'm on the highway and i accelerate the car lurches to the right a bit. then when i take my foot off, it goes to the left. What do you think this is? I thought maybe axle bearings?
justin
Posted on: 2007/12/9 22:08
Re: diff problem
Perhaps you should park it in your garage or driveway & jack it up, then inspect the suspension. Check all the mounting points, like rear spring front bushes, 'U' bolts, spring leaves [broken main leaf?] Every part that has anything to do with connecting the road wheels to the chassis.
This way you get an obviously unsafe car off the road, you learn a little about auto mechanics, & you get your answer to this question much quicker.
See, it's a win win win situation.
Make sure you place jack stands under the car before geting under it.
Posted on: 2007/12/10 13:56
Love your Datsun.
Treat it well.
Re: diff problem
From Brisbane
Thanks for such a constructive comment. if I hadn't already inspected the suspension i wouldn't be asking for help. There's no point being critical and condescending in posts.
Posted on: 2007/12/10 23:15
Re: diff problem
From gold coast QLD.
On this occasion i don't believe Dodgeman is being condescending but being thorough,based on your request for advice.
If you have checked all that has been sugested,i would now suggest you may have a broken axle.
I'm sure you know how to check this based on your last post.
Good Luck
Cheers
Posted on: 2007/12/10 23:58
Re: diff problem
From Brisbane
sorry perhaps i was harsh. Thanks for the advice all. The axles have been checked not long ago, no probs. I 'll take it to a diff specialist. cheers, justin
Posted on: 2007/12/11 2:40
