Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
What is the largest rims to put on a 1200 ute
DAT120
Posted on: 2007/12/13 21:44
whats the biggest rims that can go on my 1200 ute, with out any modification?
#2
Re: What is the largest rims to put on a 1200 ute
wolki101
Posted on: 2007/12/13 22:12
mine had 16's on it with 205 wide rubber without scraping.
#3
frankthedolphintrainer
Posted on: 2007/12/13 23:56
im pretty sure 17s are the biggest campo runs them i think
#4
crzy_1200_ute
Posted on: 2007/12/14 1:39
well i got 14's and they scrap on the guards going down driveways but thats with low springs
#5
wolki101
Posted on: 2007/12/14 1:45
yeh if you run huge wheels you can't go as low. personally i think 13's or 14's look the best. 16's or 17's look out of place and don't go with the older body styles in my opinion but it's your car.
#6
DAT120
Posted on: 2007/12/14 8:16
thanks guys, im thinking of getting 17's on a stock datsun stock hight think it will work?
#7
Tyrie
Posted on: 2007/12/14 9:16
you will need to modify the front of the guards, especially if you have repro panels. You may have issues with the offset of 17" mags on standard struts. Also with rubbing on the footwell.
#8
oca18
Posted on: 2007/12/14 10:46
i have 17s with 205 40 17 rubber on my 1200 wagon. i had to change the front strutts , cut the front of the guard at the bottom so the tyre would pass it when turning and also had to change the shape of the foot well cos the tyre scrapped there too !! i was told when i bought my wheels that they were one of the last sets of rear wheel drive offset rims avalable in austrailia..... so if you are prepared to do a few mods to get the 17s on and can find some rear wheel drive offset rims i think the end result is well worth it !!!!
#9
dats1000
Posted on: 2007/12/14 11:40
you might have a bit of a problem with the police if u put 17s
#10
Dodgeman
Posted on: 2007/12/14 15:16
It's not the diameter of the rim that's a problem, it's the outside diameter of the tyre.
If you want to go with large diameter rims, then you need VERY low profile tyres if you want to run them without problems. The stock original cross ply tyre was 575mm in diameter & a 185x40x17 tyre is a little larger at almost 580mm This will give you little or no clearance problems if the wheel offset is right. I run 205 tyres on the rear & this is probably as wide as you can go & still drive it over curbs etc. without any real problems, so a 205x40x17 will come out at 587mm OD & should fit OK under an unmodified 1200 rear wheel arch. Now all you need to do is find the right wheels & tyres. Good luck. There are many of us who think that 15" is probably the largest diameter that is cost effective, reasonably easy to find & asthetically balanced with 13's & 14's being the most popular. [with good reason] You can view topic.
