Browsing this Thread:
1 Anonymous Users
Re: different Datsuns weight from factory |
From Canberra
Quote: Mawler1 wrote: it's not on the list but a 120Y 4 door sedan(auto) is 741kg
manual version is 675 Kg
you mean 775kg for the 4spd??
Posted on: 2007/12/12 23:37
From Brisbane, Australia
Quote: beattie wrote: 240, 260, 280 What?
Z? 2+2 or 2 seater? K? C?
I think 2 seater Zs are around the high 800 mark, def under a ton. And i think the 2+2 is a little over a ton.
2 seater 240Z are 1080kg IIRC. and there ain't alot you can remove to make them lighter. the 2 seat 260Z is heavier. no-one cares what the 2+2's weigh. we'd all rather forget they were ever made.
Posted on: 2007/12/12 23:40
still would like the 260 280 weights if possible in any model 240 are fetching a good price cant find a good cheep project
also
whats the weight of a a12 engine manual box from factory out of a 1200 ute (early 70s)
still need 2 13'' rims or something else that will be the same as a 180b stockie around sydney area
Posted on: 2007/12/13 2:06
From Quairading, Western Australia
675Kg for the 4 speed
741kg for the auto
I belive that to be correct as I can lift a F4W56A and F4W60L with ease
It's a 3N71B I struggle with...
when The Defect III is complete I intend getting it weighed... just out of curiousity
just need 6 things to fix to have it drivable + glue back together the right hand taillight ring after I broke it today...
possibly planning fabricating some new ones using some thin alloy sheet (highly polished) using the mounting gaskets as templates and a few bolts to keep them restrained
Posted on: 2007/12/13 16:20
From Canberra
There's no way a 120y sedan (auto or manual) weighed less than any of the 1200s.
The 1974 'Wheels' road test of the 120Y 4door sedan 4spd manual says it weighed 775kg.
Posted on: 2007/12/13 23:51
From Far, far away
The rego papers for my ute say 690kg
Posted on: 2007/12/14 0:43
Lightest Datsun ever is the late 50s feather around 450kg.
standard versions of the 1k ute 615kg (no passenger sunvisor, radio or heater) deluxe extra 15kg 2 door 625kg (no passenger sunvisor, radio or heater) deluxe extra 15kg 4 door 645kg (no passenger sunvisor, radio or heater) deluxe extra 15kg coupe 675kg (has all the trimmings, goodies etc!)
My 2 door sedan with bumperettes and many other bits is just under 600kg.
My friend Al has a 58kg 1600cc vitara engine and sierra box and saved another 30kg. He is looking perhaps at a lightweight Winters diff to keep it that way and also lexan windows for the rear and eventually composite leaf springs to target the 550kg mark. The vitara engine will be bored for 1780cc using full sleeves and maybe boost.
Posted on: 2007/12/14 5:15
whats the weight of a stock a12 engine from a datsun 1200??? gearbox out of datsun 1200???
Posted on: 2007/12/15 0:38
From New Hampshire, USA
Gearbox weights
Comp 56 series 4 speed, 39lbs or 17.7kg Stock 60 series 5 speed, 52 lbs or 23.6kg
Posted on: 2007/12/15 15:14
Engine Weights, supposed shipping weight (I haven't confirmed)
A12 192lbs or 87kg A14/15 205lbs or 93kg
Posted on: 2007/12/15 16:01
