« 1 (2)
Re: ca18det Qs
From Sunnybank, Brisbane
im runnin a silvia box as well. what we did was panel beat the forward part of the tunnel to accomodate the bell housing a little bit of panel beating down the middle of the tunnel and got the shifter section of a tunnel from a silvia to allow the already mentioned huge shifter section, this also means (not that its a big deal) that you get the bolt holes for the gearstick boot to bolt to.
but..... if you want to be able to remove the gearbox without removing the motor the best bet is to get a silvia tunnel and cut out your old one, its not that bigger job to be honest, if i had of investigated it a bit more before doing mine, i would have gone this way
hope that helps u make a decision
jimmy.
Posted on: 2007/12/21 5:21
Re: ca18det Qs
From Mandurah, Western Australia
I have the CA18 Manual box in a 1200 Coupe which was a manual to begin with. Its a tight fit and required minor panel beating (smacking with hammer) to the tunnel. It fits quite neatly, however the motor and gearbox cant be separated while in the car. The car is lowered over the motor/gearbox and you bolt it all in. Works well.
In WA if you cut the tunnel it has to be certified by a engineer and welded by a certified welder.
Posted on: 2007/12/21 6:48
Re: ca18det Qs
From Melbourne Vic
a mate of mine wazza on this site squeezed an s13 gearbox into a standard manual tunnel with lots of hammering and some minor 'relief' points. it can be done just depends on how good you are with problem solving and fixing stuff like that.
Posted on: 2007/12/21 14:19
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Re: ca18det Qs
Quite a regular
From TOWNSVILLE QLD
nice so .. in the end silvia gear box is the way to go even if its a little bit more costly to fit becuase it a better box all round and i dont have to change the diff .. if i buy the lsd for the stock diff will it be strongenough to do proper launches and other stranous tasks
Posted on: 2007/12/22 4:04
Re: ca18det Qs
From Toowoomba, QLD
my mate just got one of those maddat tunnels and it fits like a z car into a 1200 club.
Took alot of cutting and welding to get it right and i wouldn't say we are completely useless when it comes to that sort of stuff. Have fun with the maddat tunnel!!
Posted on: 2007/12/30 9:53
Re: ca18det Qs
From perth airport
my tunnel form maddat welded in nicely , a few hours work tho , scott makes it look very ezy in his build up thread .
Posted on: 2007/12/30 10:24
perth airport parking
Datsun 1200 ute A14
Re: ca18det Qs
From brisbane
I'm with Sooty Grunter. If you have the time stitch in a new tunnel that will allow you to remove the gearbox without taking out the motor as well. I really wish I had done this during my conversion.
Matty
Posted on: 2008/1/1 1:38
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
« 1 (2)
