#1 1200 flywheel not fitting on my a12
my_1200 Posted on: 2007/12/21 23:54
hey guys
hoping you could help me out ive got a 1200 flywheel thats is not fitting onto the back of the crank the centre hole on the flywheel is to small and the stud patten is also different, and it was an auto if that makes a difference.
cheers
#2 Re: 1200 flywheel not fitting on my a12
A14force Posted on: 2007/12/22 0:54
Maybe you have an A10 one.
#3 Re: 1200 flywheel not fitting on my a12
my_1200 Posted on: 2007/12/22 1:13
flywheel do u mean the guy said it came off a 1200 and my engine number is a12
#4 Re: 1200 flywheel not fitting on my a12
Cable_Tie Posted on: 2007/12/22 1:18
This spacer comes off.
If you keep rotating the flywheel, you should eventually get the holes to line up.
(Spacer is on back of crank, right)
#5 Re: 1200 flywheel not fitting on my a12
my_1200 Posted on: 2007/12/22 7:40
thanks for that mate that was the problem
#6 Re: 1200 flywheel not fitting on my a12
reuby_tuesday Posted on: 2007/12/22 10:28
Yeah thats the one. The bolts a keyed in place, for balancing perhps?
I spent a while trying to work out why my new fancy shmancy flywheel wouldnt fit. i was even gonna take it back till i worked that out.
Luky i didnt make a fool out of myself on that one.
