help
hi what break booster you guys runnin in 1200 ute and did you have to do any mods to it
Posted on: 2007/12/27 2:22
Re: help
From perth airport
break boost ?? im unshore wat the question is
did you mean wat brake booster we use?
btw welcome to 1200 . com
Posted on: 2007/12/27 2:31
perth airport parking
Datsun 1200 ute A14
Re: help
year sorry ment booster
Posted on: 2007/12/27 2:35
Re: help
From perth airport
ok wat motor do you have ? as if its a ca18 its hard to get booster to fit maddat sell one $700
there are other ways , i have heard of different combos .
and wat brake do you have ? disks / drums /
Posted on: 2007/12/27 2:43
Datsun 1200 ute A14
Re: help
120y or 180b booster will fit a ca or sr or many other engines including stock with the correct spacer plate.
its the clutch master that may get in the way of the intake manifold
maddat setup still needs alot of work ontop of what they say and i found it hard to get any answers of any1 there but im not friends with them like other people on here
the plate thickness is a litle to thin(affects rod)
the booster rod is to long(needs short rod)
the clutch bolts hit firewall(needs countersunk)
the clutch pin didnt line up(made new 1)
the clutch reservior hit intake(made adapter for $5)
main bolt holes needed custom bushes to sit flat on wall
and if you take $120(plate) off $700(kit)
thats like a $550 booster and a $30clutch cylinder
so i would look around and do as much yourself as you can
Posted on: 2007/12/27 6:21
