diff and front struts
From Bris-vegas
hi everyone
i want to replace my diff with a skyline lsd and also do the skyline strut and break upgrade, later to be fitted with coilovers, can anyone please answer these questions.
how difficult is it to fit these items?
where i can find them?
cheers
Posted on: 2007/12/30 9:05
Re: diff and front struts
From Adelaide, SA the drift state
look in my pictures for my front strut setup reasonably cheap and gonna work well. diff i dunno
Posted on: 2007/12/30 10:39
From Stratford, victoria(the east side of melb)
try maddat for the rear end upgrade
scroll down and you will find it
maddat
Posted on: 2007/12/30 10:55
From Geelong, Vic
any diff shop should be able to sort out the diff situation
for standard width you need to swap axles left to right then shorten the long axle 155mm.....but the diff place should be able to work that out
to fit r31 front struts you need every thing you would to fit stanza or similar struts, then there are only few exrta things you need to make the r31 struts work
Posted on: 2007/12/30 12:56
From Bris-vegas
can these parts be found at my local wreckers? thanks for everyones help
Posted on: 2007/12/31 2:08
From Gold Coast Australia
Yeah wreckers are the go.
You are after an R31 skyline diff, the sillouette came out with the LSD but particalar model falcon centres will fit the skyline diff. R31 struts are also what you are after. And after that... what pigdog said
Posted on: 2007/12/31 7:20
SR20DET Sunny for sale, click me for details
