Re: t50 gearbox in a kb10 ( help with clutch thingo)
From tasmania
if it a cable clutch before it would be easy to adapt a 1200 cluctch set up I did one to a 1000 the cable nomaly runs through the bellhousing if your box hasnt got the hole where the cable goes through just make a bracket and bolt it to the belhousing you need to modify where it come out of the firewall is diferent a 1000 cable is different there to if it was hydraulic the cluch fork maybe pushing not pulling
Posted on: 2007/12/31 9:14
Subject Poster Date
     t50 gearbox in a kb10 is this the right cabel ??????? perthute 2007/12/30 23:20
       Re: t50 gearbox in a kb10 ( help with clutch thingo) sidedraught 2007/12/31 8:40
         Re: t50 gearbox in a kb10 ( help with clutch thingo) perthute 2007/12/31 9:05
       Re: t50 gearbox in a kb10 ( help with clutch thingo) baldy 2007/12/31 9:14
       Re: t50 gearbox in a kb10 ( help with clutch thingo) vixen 2008/1/1 2:04
         Re: t50 gearbox in a kb10 ( help with clutch thingo) perthute 2008/1/4 1:25
           Re: t50 gearbox in a kb10 ( help with clutch thingo) sidedraught 2008/1/4 2:46
             Re: t50 gearbox in a kb10 ( help with clutch thingo) qik1000 2008/1/4 4:34
               Re: t50 gearbox in a kb10 ( help with clutch thingo) perthute 2008/1/4 6:27
