tcd ?
From Brisvegas, oz
to get the tcd (valves) is it the timing mark set at 0 degrees? im confused with setting the clearances. i tried understanding this method but got confused.
clicky
he says that when 2 is on the rock check 3; 1 on the rock check 4; when 3 is rocking check 2: 1-3-4-2, but then how do you find out when they are on the rock??
Posted on: 2008/1/5 7:35
www.camerasplus.com.au
Re: tcd ?
From Sydney (Carlingford)
Yes, when the timing mark is on "0" that is Top Dead Centre (TDC) and the valves are fully closed on the cylinder that is firing (which will be either No: 1 or No: 4 cylinder).
When you do the distributor timing, it is set at about 10 degrees Before Top Dead Centre "BTDC". This allows time for the burn to expand and be compressed before sending the piston back down the bore.
If you are setting the tappet adjustment you should be able to put the timing mark at TDC and adjust four of the tappets then rotate the crank once back to TDC and adjust the other four.
Hope tha helps.
Posted on: 2008/1/5 7:48
Re: tcd ?
From Brisvegas, oz
aahh that helps a bit.
Posted on: 2008/1/5 7:50
Re: tcd ?
Good, if you are not sure which four to adjust each time just look at the cam lobes and adjust the 2 that are pointing upwards in a V shape (Will be either No1 or No4 cylinders).
There will also be another 2 cam lobes one on each of No: 2 and 3 cylinders that also point out in either side of the V shape and you can adjust those as well.
When you rotate the crank 360degrees you will pick up the others.
Posted on: 2008/1/5 8:01
Re: tcd ?
From Brisvegas, oz
if you cant see the cam how do you check the other 2 cyclinders, or does setting it from from the system
No. 1 TDC: Adjust valves 1,2,3,5 (counting from front of engine)
No. 4 TDC: Adjust valves 4,6,7,8
correct all cylinders
Posted on: 2008/1/5 8:17
Re: tcd ?
Sorry, my fault I am used to working on L series obviously with over head cam. He He
Same principal applies though, you just cant see the cam.
Yes you are correct:
Sorry still getting used to this A series stuff.
Posted on: 2008/1/5 9:13
Re: tcd ?
From Bris-Vegas
Presume you're using a feeler gauge to set your tappet clearances & not working with a shim & bucket setup......
You can set the clearance at any stage on the cam as long as it's not the transition to the "lumpy" bit.
Posted on: 2008/1/5 11:15
CA18DET '74 1200 ute project
Re: tcd ?
From Brisvegas, oz
alls good did it this arvo
Posted on: 2008/1/5 11:26
