ca18det
Quite a regular
From rockhampton, queensland
hey guys i have recently just heard that a nissan bluebird gearbox will fit a ca18det. Just want to know is this true or is someone pulling my leg.
cheers
Posted on: 2008/1/8 1:37
Re: ca18det
From Melbourne, Australia
it will bolt up if it's from a CA20 bluey, not sure how big it is for fitting into a 1200 tunnel
people use the bellhousing from this box with a skyline gearbox to create a short box for easy fitment to a 1200
Posted on: 2008/1/8 1:39
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: ca18det
From Wagga Wagga
even if it did fit the gearbox would be stuffed if you drop the clutch too many times!
Posted on: 2008/1/8 1:40
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
Re: ca18det
From Far, far away
From what I've been told the CA20 'box is surprisingly strong, alot stronger then the CA20 engine needs.
Anyway, no 'box will stand up to continuously dropping the clutch. 'Treat 'em mean, keep 'em keen' doesn't apply to gearboxes.
Posted on: 2008/1/8 1:45
Re: ca18det
Quite a regular
Rito cheers thats all i needed to know.
Posted on: 2008/1/8 1:53
Re: ca18det
From Sydney, Australia
You also need to consider if the CA18 flywheel will fit inside the CA20 bellhousing.
The bellhousing flywheel/clutch thing is something else to consider, on top of 'will it bolt up'.
If the CA18det flywheel and clutch fits in the ca20 box, that's great. Otherwise you might need to use a CA18de flywheel and clutch (which is smaller). Maybe even a FWD flywheel and clutch, which is smaller again.
With all this chopping and changing, you might need a different starter motor.
I have a feeling that someone else on here is running a CA20 box in their CA18det Ute...
Posted on: 2008/1/8 3:20
