Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: forged internals for ca18det
mcgee
Posted on: 2008/1/7 23:58
There are a heap of little extras that all add up (may not need all but should budget for them).
Oil pump, water pump, machining and balance, Head work (Cam followers, valve stems, springs, cams), welsh plugs, timing tensioners, thermostat, spark plugs, oil, oil filter, rubber hose to replace perished ones, Radiator flush, coolent. Then there is the turbo, ECU, boost controller, ignitors, Fuel pump, fuel filter, injectors, pressure regulator and finally the tune. +++ im sure. I think my engine owes me around $7k including a new ECU. She is making 199rwHP on 7psi (rev limited to 6500rpm for runin period 1400km on the clock now). May not sound that impressive.......yet :).
#12
Ronald
Posted on: 2008/1/8 0:46
i think you'll probalbly find that 8.5:1 static compression ratio is more than capable of handling 300rwhp plus easily with good internals and good head gasket with a correct tune. JUN would be the company i would go to if i had a big cheque book, but otherwise i'm sure all forged internals are better than the stock ones.
#13
phat_dat1200
Posted on: 2008/1/8 3:59
if you don't mind getting stuff offshore import performance parts in the us sells a rebuild kit with:
Complete Gasket Set Copper/MLS Head Gasket Wiseco Forged Pistons (83, 83.5, 84mm Bore) and (8.5, 8.8:1 compression) JE Piston Upgrade available for addt'l $49 Plasma Moly Rings Performance Wrist Pins TOGA HP Main Bearings TOGA HP Rod Bearings Freeze Plugs for $1054aud so about $1200 shipped you will not find better than that in australia
#14
short-coupe
Posted on: 2008/1/8 4:02
mcgee what ecu r u running now?
#15
Laney
Posted on: 2008/1/8 4:28
lol basic internals i know bout all the ad ons . . and im not sure what com im running as i think ill be looking for a new one soon lol want to stay with microtech though anyone want to sell one?
#16
mcgee
Posted on: 2008/1/8 8:19
Short-coupe,
I replaced the wolf with a microtech LT10s with X4.
#17
Laney
Posted on: 2008/1/8 11:37
how u find the microtech compaired to the wolf? whats better?
#18
allwaysallin
Posted on: 2008/1/8 13:35
i dont no about microtec but i know that heltec is a good computer but its all about how much u are willing to fork out for theese things stock will do me for a while well untill im looking for some seriouse power( 250rwkw) but almost any aftermarket computer will handle things better than the stock one well if u keep to the major brands anyways.
thanks allwaysallin
#19
mcgee
Posted on: 2008/1/9 0:50
It's hard to compair apples with apples as my wolf was a v3 (Mid 1990s) and the microtech is brand new. At the end of the day it's what your tuner is most comfortable with that will get the most horsepower. I definitly made more Hp with the microtech at lower boost levels then with the wolf but that is not a limitation of the computer but shows how comfortable the tuner is with microtech.
