Re: A12 MAX Overbore???
Pushing a 1200 or A12 block past 77mm is pushing your luck, but 77mm should be OK in most blocks.
You might want to do the math in relation to the 1974 US model A13 block. This is basically an A14 but with the smaller 73mm bore size & is stamped A13 as the prefix to the engine number. [73mm x 77mm + tall deck block]
US only, .... one year only, so it's not common, but they do exist & might be a solution to your problems.
Posted on: 2008/1/9 8:19
Love your Datsun.
Treat it well.
Subject Poster Date
     A12 MAX Overbore??? tjracing 2008/1/8 7:38
       Re: A12 MAX Overbore??? Ronald 2008/1/8 7:40
         Re: A12 MAX Overbore??? tjracing 2008/1/8 7:47
           Re: A12 MAX Overbore??? TnPshow 2008/1/8 7:50
             Re: A12 MAX Overbore??? Ronald 2008/1/8 9:29
               Re: A12 MAX Overbore??? tjracing 2008/1/8 9:46
                 Re: A12 MAX Overbore??? Dodgeman 2008/1/9 8:19
                   Re: A12 MAX Overbore??? tjracing 2008/1/11 22:42
                     Re: A12 MAX Overbore??? tjracing 2008/4/6 4:14
           Re: A12 MAX Overbore??? ddgonzal 2008/1/8 7:50
             Re: A12 MAX Overbore??? tjracing 2008/1/8 8:01
