« 1 (2)
Re: Tacho help please???
From Adelaide, SA
cheers that should definately help, hopefully this will help a few others out to.
Posted on: 2008/1/10 7:26
From Adelaide, SA
just had a thought would wire comming from ecu to the power transistor be putting out the signal needed? it would only be a single wire then and would be easier to get to.
Posted on: 2008/1/10 7:38
From Adelaide, SA
No, have a look at the diagram - theres 4 wires from the ECU, 1 for each coil.
There's 4 power transistors inside the Power Module.
Each one is separate so that there's minimum interference between each circuit.
Posted on: 2008/1/10 7:53
From Adelaide, SA
of course cool alright well ill give it a shot over the weekend and let everyone know if it works
Posted on: 2008/1/10 9:20
From Sydney, Australia
I just read it was an aftermarket. I agree with the approach of using the power transistors to get a single signal.
When wired wrong, I've heard of the SR20/CA18 factory ECU tacho driver burning out.
Going to the source is a good idea.
Posted on: 2008/1/10 11:42
From Adelaide, SA
Okay so i have been very lazy but i finally fixed the tacho. i followed TnPshow's diagram at it worked perfect. I cut into wires at the power transistor unit using the four outgoing wires as it was easier to get to. as for diodes i just used the biggest ones Dick Smiths had. better to be safe than sorry. hoepfully this helps a few people out. cheers
Posted on: 2008/2/5 5:09
« 1 (2)
